Some fields are missing in raw data but visible in GroupBy Terms
    Grafana v.9.4.3 in CentOS
    View raw data from specific Data source.
    Select table in visualization
    Select the correct data source >> Change metrics to raw data.
  • What happened?
    Upon checking some fields are not in raw data but when checked in kaizen, data exist, so I tried approaching the data in other way and fields was visible in Group by Terms
    See all fields for that data source.
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. I didn’t receive any errors.
    No, I did not.
