Sourcecode build rpm for arm64 arch in x86_64 environment
v8.4.6
    I want use nfpm package grafana in sourcecode generate rpm for arm64 arch in x86_64 environment, this can avoid depend on others like urw-fonts .
  • compile env prepare
  • 0、install git
    yum -y install git
  • 1、install golang
    [root@demo BUILDSCRIPTS_CTREMEL]# cat /etc/profile|grep GO
    export GOROOT=/usr/local/go
    export GOPATH=/root/gocode
    export PATH=$GOPATH/bin:$GOROOT/bin:$PATH
    export GOPROXY=https://goproxy.io,direct
  • 2、install nodejs
    npm root -g
    npm install express -g
    npm install -g cnpm
    npm install -g yarn
    npm config set registry
    npm install -g @vue/cli
    cnpm install -g @vue/cli
    yarn -v
    cnpm -v
  • some conf
    [root@demo BUILDSCRIPTS_CTREMEL]# tail -5 /etc/profile
    #set nodejs npm yarn environment
    export NODE_HOME=/usr/local/nodejs
    export PATH=$NODE_HOME/bin:$PATH
  • make rpmbuild config file
    [root@demo ~]# mkdir -p gocode
    [root@demo ~]# cd gocode/
    [root@demo gocode]# ll
    total 0
    drwxr-xr-x 2 root root 58 Aug 17 09:52 bin
    drwxr-xr-x 4 root root 30 Aug 16 16:38 BUILDSCRIPTS_CTREMEL
    drwxr-xr-x 4 root root 30 Aug 16 16:57 pkg
    drwxr-xr-x 5 root root 61 Aug 16 16:37 src
    [root@demo gocode]# mkdir -p BUILDSCRIPTS_CTREMEL/{conf,dist}
    [root@demo gocode]# ll BUILDSCRIPTS_CTREMEL/
    total 0
    drwxr-xr-x 2 root root 31 Aug 17 10:27 conf
    drwxr-xr-x 2 root root 40 Aug 17 09:59 dist
    [root@demo gocode]# cd BUILDSCRIPTS_CTREMEL/
    [root@demo BUILDSCRIPTS_CTREMEL]# ll
    total 0
    [root@demo BUILDSCRIPTS_CTREMEL]# pwd
    /root/gocode/BUILDSCRIPTS_CTREMEL
    [root@demo BUILDSCRIPTS_CTREMEL]# vim conf/grafana_nfpm.yaml
    [root@demo BUILDSCRIPTS_CTREMEL]# cat conf/grafana_nfpm.yaml
  • grafana_nfpm.yaml
arch: "aarch64"
platform: "linux"
version: "8.4.6"
section: "default"
priority: "extra"
release: 1
replaces:
- grafana
provides:
- grafana-server
- grafana-cli
depends:
- coreutils
- shadow-utils
maintainer: "<contact@grafana.com>"
description: |
  Grafana
vendor: "Grafana"
homepage: "https://grafana.com"
license: "Apache 2"
contents:
        - src: ./bin/linux-amd64/grafana-server
          dst: /usr/sbin/grafana-server
        - src: ./bin/linux-amd64/grafana-cli
          dst: /usr/sbin/grafana-cli
        - src: ./packaging/rpm/init.d/grafana-server
          dst: /etc/init.d/grafana-server
        - src: ./packaging/rpm/sysconfig/grafana-server
          dst: /etc/sysconfig/grafana-server
          type: config|noreplace
        - src: ./packaging/rpm/systemd/grafana-server.service
          dst: /usr/lib/systemd/system/grafana-server.service
        - src: ./public/
          dst: /usr/share/grafana/public
        - src: ./conf/
          dst: /usr/share/grafana/conf
        - src: ./conf/
          dst: /etc/grafana
scripts:
    postinstall: ./packaging/rpm/control/postinst
rpm:
    scripts:
        posttrans: ./packaging/rpm/control/posttrans
  • build.sh in ~/go/src/github.com/grafana dir
#!/usr/bin/bash
export NODE_OPTIONS=--max-old-space-size=8192
export GRAFANA_VERSION="v8.4.6"
export PATH=${GOPATH}/bin:${PATH}
cd ${GOPATH}/src/github.com/grafana
rm -rf grafana
git clone https://github.com/grafana/grafana
cd grafana
git checkout -f $GRAFANA_VERSION
BUILD_VERSION=$(git describe --tags)
if [[ "$BUILD_VERSION" != "$GRAFANA_VERSION" ]]; then
        echo "Version missmatch, look after git tag"
        exit 1
else
yarn install
yarn build
make gen-go
go run build.go setup
go run build.go build
# Todo rpm build with nfpm
${GOPATH}/bin/nfpm pkg --packager rpm --config ${GOPATH}/BUILDSCRIPTS_CTREMEL/conf/grafana_nfpm_arm.yaml --target ${GOPATH}/BUILDSCRIPTS_CTREMEL/dist
fi
  • What happened?
    when build.sh execute go run build.go build ,some errors happend
[root@mathewwu ~/go/src/github.com/grafana/grafana]# go run build.go -goarch=arm64 -cc=aarch64-none-linux-gnu-gcc -goos=linux  build
    I was nfpm build success in this way before, but arm64 arch happend error , I don’t know how what should i do? Does anyone know what’s going on?
Try to install ssl dev package before compilation - openssl-dev or libssl-dev package.
openssl-dev or libssl-dev default installed in system, but wasn’t solved
