Space (gap) between title and stat
Hi
I would like to know if I can change the gap between my stat and my title as you can see here :
It’s so huge we can think that the title is for the stat upside :slight_smile:
Thanks a lot
Try 6.2 beta1 it’s been improved
ok thanks a lot
I can upgrade easily without losing my dashboard ? :slight_smile:
We always recommend taking a backup before upgrade just in case, see https://grafana.com/docs/installation/upgrading/.
I did it, I’m in beta now
but still same for gauge panel (left), better for single stat (right), but in single stat low capacity of Thresholds
That seems like a bug. Care to open a bug report here so we can investigate it further? Thanks
