What Grafana version and what operating system are you using? 7.5.4
I imported grafana JVM Micrometer dashboard id: 10731. However, Application variable on the dashboard is showing as “None”
Anyone here has experience as to how to make the Application variable contains actual application name? Source is data is prometheus.
Thanks!
Do you have the prometheus datasource configured already? Can you return queries on it? If so I would go to the Dashboard settings and inspect the query used for each variable:
