I am using LetsEncrypt’s certbot to auto-renew SSL/TSL certs every 3 months on an Ubuntu machine.
The cert works fine if I place the *.pem
files into /etc/grafana
and change the grafana.ini
file to point to that location.
However, if the *.pem
files are left in /etc/letsencrypt/live/<my-domain>
then Grafana fails to start with the following appearing in grafana.log
t=2021-12-13T09:28:35+0100 lvl=eror msg="Stopped HTTPServer" logger=server reason="open /etc/letsencrypt/live/<my-domain>/fullchain.pem: permission denied"
t=2021-12-13T09:28:35+0100 lvl=eror msg="Server shutdown" logger=server error="HTTPServer run error: open /etc/letsencrypt/live/<my-domain>/fullchain.pem: permission denied"
I’ve tried everything I can think of, and have even set the permissions for both the /etc/letsencrypt/live/<my-domain>
folder and pem files to drwxrwxrwx
for all users (chmod a+rwx
It’s important to me that I can specify that location for Grafana to read from so that I don’t need to copy the files over every time the SSL / TSL certs auto-renew every 3 months.
Why can Grafana not access those pem files in that location?
@adam5840
are you serving Grafana behind a reverse proxy like nginx?
Hi matt, yes I am using a reverse proxy…
Are you running 8.3.5+? If so, you might need to add a new header to your config. This was noted in the changelog but it was buried:
opened 04:36AM - 09 Feb 22 UTC
closed 06:25PM - 10 Feb 22 UTC
type/docs
**What happened**:
Unable to create a new dashboard or save changes to existing… dashboards following update to Grafana v8.3.5
**What you expected to happen**:
Ability to create/modify dashboards in Grafana
**How to reproduce it (as minimally and precisely as possible)**:
- Log into Grafana instance and click on "+" button and create new dashboard
- Go to save the dashboard into a folder
- Attempt to save fails, "Origin Not Allowed" error shows up in upper right corner
**Anything else we need to know?**:
Attached is what I'm seeing in the console upon trying to save; looks like it is getting a 403 Forbidden for FQDN/api/dashboards/db and this is preventing dashboard from saving. Clicking the "Save" button prompts one of these errors in the console. I'm also seeing a 403 Forbidden on FQDN/api/frontend-metrics and a screenshot for that is attached too. I'm not seeing anything of particular use in the /var/log/grafana/grafana.log at INFO level, let me know if I should try debug level.
<img width="1676" alt="Screen Shot 2022-02-08 at 10 26 05 PM" src="https://user-images.githubusercontent.com/16138910/153122711-779a4b11-48f3-4071-a5da-b7dd218859de.png">
<img width="1675" alt="Screen Shot 2022-02-08 at 10 31 46 PM" src="https://user-images.githubusercontent.com/16138910/153122716-9a93814d-2712-43ee-83cf-6883646cfb9c.png">
**Environment**:
- Grafana version: 8.3.5
- Data source type & version: InfluxDB
- OS Grafana is installed on: RHEL 8
- User OS & Browser: Safari, Chrome
- Grafana plugins: None
- Others: None
