I created a stacked graph with two queries,
but on the hover effect, it sums up the two queries.
For example:
Lohweg is 3,33 kWh; Halle is 3,71 kWh; Sum is 7,04kWh
How can I set up the dashboard to show QueryA and QueryB and not the sum of both.
Hope you can help me.
Best regards, Martin
Could it be a problem since fixed? I don’t see that behavior with 7.2 using InfluxDB and vaguely recall seeing it a while back. My hover display shows the individual contributing values.
The “Hover tooltip” has a “Stacked value” that you can change to “individual” to get the behavior you want. It defaults to cumulative.
