Hello Folks,
Being my first post here, I would like to thank you all for the awesome product that you make it available for free!
Coming to my question, I was able to star the dashboards using the API for which I used the admin credentials. But, per our integration, most of the users would be logging in using OAuth. Since the star API is per user, how can I star the dashboards for these OAuth users ?
Is there any API using which I can make the stars globally visible ?
Thanks in advance.
