device_id | bucket | status
1 | 1970-01-01 01:22:30 | ACTIVE
1 | 1970-01-01 01:22:25 | ACTIVE
1 | 1970-01-01 01:22:45 | ACTIVE
1 | 1970-01-01 01:22:40 | ACTIVE
2 | 1970-01-01 01:22:35 | ACTIVE
2 | 1970-01-01 01:22:05 | ACTIVE
2 | 1970-01-01 01:22:20 | ACTIVE
2 | 1970-01-01 01:22:00 | ACTIVE
1 | 1970-01-01 01:22:15 | ACTIVE
1 | 1970-01-01 01:22:10 | ACTIVE
I think the state timeline is expecting data like this:
bucket | device1 | device2
1970-01-01 01:22:30 | ACTIVE| ACTIVE
1970-01-01 01:22:25 | ACTIVE| ACTIVE
1970-01-01 01:22:45 | ACTIVE| ACTIVE
1970-01-01 01:22:40 | ACTIVE| ACTIVE
1970-01-01 01:22:35 | ACTIVE| ACTIVE
1970-01-01 01:22:05 | ACTIVE| ACTIVE
1970-01-01 01:22:20 | ACTIVE| ACTIVE
1970-01-01 01:22:00 | ACTIVE| ACTIVE
1970-01-01 01:22:15 | ACTIVE| ACTIVE
1970-01-01 01:22:10 | ACTIVE| ACTIVE
But I’m using Postgres, and to do a pivot table like this, I have to use crosstab() and hardcode the output columns. Can I use a data transformation do to this please?
Unfortunately I’ve got an unknown number of devices at run time, so I can’t use multiple queries - this normally works by specifying the metric column in “Time Series” but the metric column doesn’t seem to work with the State Timeline
I have exactly the same problem. I expected that the metric column would define the swim lanes dynamically. This would be the same behavior as line graphs on a Timeline panel.
Registred to + to that
Got table with events statuses and entities
Exact entities is unknown in advance - have to use repeat pannel for each entity, want to see all of them on same graph in swimlanes
You have to read into the Multi-frame time series and how it works.
“Each frame has two fields: time, value”
“All Values are numeric” <— this is destroying both of us.
In Rotario’s case this works for him since his devices are numeric.
I have similar data to your columns ID and Max_state_s and it does not work.
This triggers the transformation for me:
SELECT
<timestamp_column> AS “time”,
case when <value_column>=‘x’ then 1
when <value_column>=‘y’ then 0
else -1
end as status,
job_name
FROM
WHERE $__timeFilter(<timestamp_column>)
The problem I encountered now is the data for values showing an infinite value:
@sgammma I’ve done as you said and it works for one series, but not another.
The timeline shows data in it, but all of the values are identical (even though I know there are different states). It seems to get messed up when I do the Group to matrix transformation.
My data in the table view looks fine, and the only difference I can see between the working and not working one is that the not working one has multiple series (or frames) appear in a dropdown, so I need to use the Merge transformation
No problem @sgammma . One thing I did notice is that “Grouping to matrix” reduces the table down to a point every 5 seconds (coincidental wit the Panel’s min-interval). If I change that to 1s, I get more data points, but they are still all the same state value.
I wonder if there are just too many points, and it is selected the last for each time interval.
I think I just solved my problem. I had misunderstood the series. It was reporting all states, and the value field indicated whether that state was enabled. So I just needed to add == 1 to my query so I get the actual state.
Maybe someone finds this handy. I could not make this work, so I have made little bit easier workaround.
I have created dashboard variable that is hidden and which is a query type and that gets all ids in selected time interval. It needs to have “all” allowed. After that I created state timeline graph repeating on that variable. It has a little caviate of having it in separate graphs, but results look almost the same.
