I want to display two values within one Stats panel. Temperature and humidity of a server room.
These two values have different thresholds.
Is it possible to have different thresholds for these two stats?
Would be useful to have the Field tab for every query…
Haven’t found an option for that…
You need to use Overrides for this. In the Overrides tab, you can select a serie and, then, override any option that you have on the Field tab, only for the selected serie.
