Grafana Cloud -
I’m trying to monitor about 30 Python scripts I’ve made. Some run continuously, others periodically. I need a dashboard displaying their current status (good/bad) and alerts when any of them fail. -
I’m creating a new script that will run periodically, get information about the other scripts and insert it into Grafana Cloud.
I’m not sure about what datasource to use, but since I need to push the data, I discarded Prometheus and I’m trying to push it to the Loki instance Grafana Cloud offers.
I’ve managed to push some test logs into it, but I’m lost now…
- Is there a panel I could use to list the status of each script? In the logs I tried using the name of the script as the value for a label “service” (e.g.: service=script1). In the dashboard, I tried adding a table panel, querying for a common label (logger=test), but it didn’t work, it adds a select to change the table for each script, and not all scripts status in the same table. It also displays one row per log entry, but for the status I just need the last log entry of each script. I also tried using vonage-status-panel, but it doesn’t seem to support Loki.
- Is there a way to automatically create an alert for each script (each value of the label script)?
Thanks for the attention.
