- What Grafana version and what operating system are you using?
grafana-9.0.0-1.x86_64
on RHEL 8.4 EUS x86_64
with prometheus 2.32.1
as data source
- What are you trying to achieve?
Understand concepts behind Min interval
and Min step
relatively to $__interval
and $__rate_interval
use in range vector parameter and the step
parameter ultimately passed to Prometheus range query
- Did you follow any online instructions? If so, what is the URL?
I’ve read documentation and This blog post and watched this talk
I’m trying to figure out some experienced behaviors when tweaking Min step
and/or Min interval
while range vector parameter is $__interval
and/or $__rate_interval
My understanding of the $__rate_interval
var, defined as max($__interval + Scrape interval, 4 * Scrape interval)
is that it solves the problems which can occur when using $__interval
as a range vector range parameter which are:
- no more data when too much zoomed in
- sudden change of data on interval boundaries
while still having the initial desired effect of $__interval
which is not to miss peaks when range vector range parameter is a lot smaller than time range
I understand that Min interval
has no effect on $__rate_interval
according to the above formula
My understanding of Min step
is that it is specific to Prometheus datasource and that it can be used to indicate a specific scrape interval different than the global one and that when set, it will not change $__interval
value
my understanding of Min interval
is that it is not specific to a particular datasource and that, if set, it will override $__interval
value
At first I thought that the step
of the range query was $__interval
except when Min interval
was set (then step
would be Min interval
) or Min step
was set (then step
would be Min step
). But this does not seem to be always the case so my reasoning must be incorrect.
For instance, when not too much zoomed in (let’s say last 6 hours), the above behavior seems to be true with a metric looking like:
rate(process_cpu_seconds_total{...}[$__rate_interval])
But not anymore when much more zoomed in (let’s say 30 last days)
So basically my question are:
- what excatly are the conceptual differences between
Min interval
andMin step
? - why
Min interval
does changeinterval
butMin step
does not ? - what happens when both
Min interval
andMin step
are sent ? - how is the
step
parameter of the range query sent to Prometheus calculated ? - why does documentation states that
Min interval
changes with resolution (and are we talking here about pixels or chosen time range) ?
Thanks for your help
