Strange Error Fetching Data
    9.0.2 on k8s
    Add more than 2 querys in one Panel
  • What happened?
    We have been using Grafana for some time now to monitor a few things. So far without problems. But recently Grafana seems to be able to handle only 2 queries per panel. If I add a third query, Grafana first takes a long time and then aborts with a query error.
    However, I can understand that the query fits if I simply enter it first in the panel. Then the desired data is displayed without any problems.
    That all queries are processed in one panel without outputting errors
It also doesn’t matter what data I access in InfluxDB. I have the error with every panel and every dashboard I create.
The displayed planes consist of only one query
    No. I don’t know where to look
try rolling back to 8.x version or spin up a secondary grafana instance in 8.x and see what happens.
Seems to occur with 8.5.5 as well.
At first the query ran without problems (no matter how many queries I put in a panel), now (after 2 hours) only parts of the panel are displayed again. Currently still 3, but as soon as I add a fourth query I get the same problem again.
