Hello. I used sum aggregations for making metrics collected every second more readable. After updating grafana I found out that this feature seems to be depreciated. Does anyone know alternative/workaround?
Hi @mmgolovatov
Looks like your using the Zabbix App / Datasource, yes?
I think the best thing to do here is to make an issue in the grafana-zabbix plugin repo.
The Zabbix plugin repo is very well maintained
