SUM is not working properly
I know this is a basic question, but I have been watching video tutorials and read online, but new to Grafana and things are not working out for me, I decided to ask here for help.
I have Grafana integration with InfluxDB and HomeAssistant, I am trying to pull data and get daily power usage in this particular example.
I have smart outlets, Home Assistant is recording the consumption value once every 1 min.
When I do SUM I do expect all values to be SUMed into one number, but it’s not the case. I am asking for help to tell me what do I do wrong…
Thanks in advance.
Hi @departy ,
Have you tried adding a transformation to your query?
@departy just another guess in addition to what @mattabrams said - if you’re literally looking for the sum total of all readings within your time range, then you need to remove the GROUP BY time($interval) element.
Having a GROUP BY time($_interval) is what you want when plotting a graph, since then your time range will be subdivided into multiple short intervals, and your query will get the sum of power readings in each interval. But if you need a single total value (and not a graph) then you need to remove that interval grouping. And probably switch to a stat panel, or something similar that’s suited for displaying a single value.
