Sum of max value per Month
Hi Community!
Can anybody help me with MYSQL.
(Grafana 9.2.6)
I have a bar with kWh/Day.
These are the max values of the day from MYSQL.
Now I wont the sum of these values per month.
Bildschirmfoto vom 2022-12-02 08-22-20
Here is the code:
SELECT
DATE_FORMAT(time, '%Y-%m-%d') AS DAY,
  max(value) AS "KWH_pro_Tag"
  FROM Item125
GROUP BY DATE_FORMAT(time, '%Y-%m-%d')
ORDER BY DAY DESC
Welcome
So your issue is not really grafana but mysql. That said change date formats to
%Y-%m
Hi, when I change this,
I only get the max value of a day in the month not
the sum of this values.
Again you might be better of posting on a mysql forum
Select sum(KWH_pro_Tag),
DATE_FORMAT(DAY, '%Y-%m) as DAY
 from
SELECT
  FROM Item125
) mx
GROUP BY DATE_FORMAT(DAY, '%Y-%m')
ORDER BY DAY DESC
Something like this maybe?
Yes :slight_smile: :slight_smile: you are a genius!!
