Suppress Giga/Mega/Kilo unit conversion for stat panel
I would like to configure a Stat panel to represent exactly the readings of my power meter.
The power meter’s display unit is “kWh”.
This is the unit, I also selected in the stat panel’s configuration.
Output: “16.93203 MWh”
Expected behavior: “16932.03 kWh”
Is there a way to suppress Mega/Kilo-conversion?
I know I can configure none unit. The number is shown correctly then,
but I’m not aware of a solution to add the unit to some label for a stat panel.
https://localhost:3000/t/dont-convert-value-to-kilo-giga/59890
