Synthetic Metrics
Hi All,
could you please help me anyone for Synthetic Metrics in Kubernetes
API current status
API Uptime (selected Interval)
average latency
are you using grafana cloud?
  • Please review the submission template and include more details:
  • What happened?
And please remember the Grafana Forum’s 3 BEST PRACTICES:
  1. Please post inside a subcategory
  2. For questions and advice, please try to use the template below
  3. If you post a question and someone solves it, please mark is as SOLVED
~ THANK YOU!!
