Table panel issue with grafanan v8.1.1
In the previous version of garafana, I was showing the multiple measurement in the table. But in the current version, i can not show all of them at the same time.
for example, above i have three measurements to show but i can show only once at a time.
Please help me. I have tried various option but could not find the solution.
Thank you.
Change the Panel type to Table and the Format as Time Series?
Thank you very much.
I have tried but unfortunately no success
Could you still guess where i am doing mistake???
I don’t really know Influx but can you define the columns,
time, data1, data2, data3 etc
ORDER BY time DESC
Table in top right done
Bottom Left: Format as: → Table
and It should show side by side in my mind
