Table Panel trims leading + or 0 characters from SQL string
Dear Community,
I wrote a simple SQL query that outputs phone-numbers as a string formatted like ‘+4912345678’.
When I create a panel, visualized as a table Grafana trims my leading ‘+’ or ‘00’ characters from the result field. I tried several things but cannot figure out on how to get the full string displayed.
This is the grafana output:
This is the actual SQL result:
This is my query :slight_smile:
Select TOP(20)
FORMAT(CallReceived,‘HH:mm’) AS Call,
PhoneNumber AS Number,
ContactCompany AS Company,
ContactName AS Contact,
FROM
X
Order BY CallReceived DESC
Dear community. I’d be very grateful for any hint on how to resolve this.
Add a field override for the field, with “Unit” as “Misc → String”
Appreciate the tip but that’s nuts to have to do that. What would posses a sane person to format a string as a number by default?
