Template stopped running query
Hi.
I have a dashboard (with Cassandra metrics) and uses templating. It defines a variable named instance like this:
label_values(up{job=“cassandra”}, instance)
For some reason, the list is returning empty.
The thing is that used to work until yesterday, and after a restart, it’s not loading anymore.
The query is correct – if i create a new dashboard and set up templating exactly with the same parameters it works (returns a list of instances).
Testing directly on prometheus (“up{job=“cassandra”}”) it works as expected too.
I’m using grafana 4.6.3-1.
Any thoughts?
Thank you.
Just found the reason.
The graph period was set to a few weeks ago where not data is available anymore. Setting to the “last 24h” it works.
Thanks.
