Tempo - Minio S3 troubleshooting
I have set up Tempo via Helm Chart and the following configuration for S3 in Tempo:
backend:
    s3:
      bucket: tempo
      endpoint: minio-s3.minio.svc.cluster.local
      access_key: **
      secret_key: **
      insecure: true
  storage:
    trace:
      backend: local
      local:
        path: /var/tempo/traces
      wal:
        path: /var/tempo/wal
The python app i use to test:
from flask import Flask, request
from opentelemetry import trace
from opentelemetry.sdk.trace import TracerProvider
from opentelemetry.exporter.otlp.proto.grpc.trace_exporter import (
    OTLPSpanExporter,
from opentelemetry.sdk.trace.export import BatchSpanProcessor
app = Flask(__name__)
span_exporter = OTLPSpanExporter(
    endpoint="tempo.monitoring.svc.cluster.local",
tracer_provider = TracerProvider()
trace.set_tracer_provider(tracer_provider)
span_processor = BatchSpanProcessor(span_exporter)
tracer_provider.add_span_processor(span_processor)
tracer = trace.get_tracer_provider().get_tracer(__name__)
@app.route("/server_request")
def server_request():
    print(request.args.get("param"))
    return "served"
if __name__ == "__main__":
    app.run(port=8082)
In my Nginx ingress I can see:
{"log":"10.0.1.238 - - [02/Nov/2021:09:43:23 +0000] \"POST /opentelemetry.proto.collector.trace.v1.TraceService/Export HTTP/2.0\" 200 5 \"-\" \"grpc-python/1.41.1 grpc-c/19.0.0 (osx; chttp2)\" 1001 0.002 [monitoring-tempo-4317] [] 10.0.0.26:4317 47 0.004 200 e6b94ca73b5667dd710d5e42961b581d\n","stream":"stdout","time":"2021-11-02T09:43:23.563588542Z"}
So the ingestion seems to be successful.
Logs from Tempo:
level=info ts=2021-11-01T08:46:30.701107722Z caller=main.go:190 msg="initialising OpenTracing tracer"
level=info ts=2021-11-01T08:46:30.720934127Z caller=main.go:109 msg="Starting Tempo" version="(version=, branch=HEAD, revision=e586b3380)"
level=info ts=2021-11-01T08:46:30.724209061Z caller=server.go:239 http=[::]:3100 grpc=[::]:9095 msg="server listening on addresses"
level=info ts=2021-11-01T08:46:30.724620278Z caller=frontend.go:30 msg="creating tripperware in query frontend to shard queries"
level=warn ts=2021-11-01T08:46:30.725623406Z caller=modules.go:145 msg="Worker address is empty in single binary mode. Attempting automatic worker conf
iguration. If queries are unresponsive consider configuring the worker explicitly." address=127.0.0.1:9095
level=info ts=2021-11-01T08:46:30.725866856Z caller=worker.go:113 msg="Starting querier worker connected to query-frontend" frontend=127.0.0.1:9095
ts=2021-11-01T08:46:30Z level=info msg="OTel Shim Logger Initialized" component=tempo
level=info ts=2021-11-01T08:46:30.727561229Z caller=module_service.go:59 msg=initialising module=store
level=info ts=2021-11-01T08:46:30.727921407Z caller=module_service.go:59 msg=initialising module=server
level=info ts=2021-11-01T08:46:30.728098062Z caller=module_service.go:59 msg=initialising module=query-frontend
level=info ts=2021-11-01T08:46:30.728258452Z caller=module_service.go:59 msg=initialising module=memberlist-kv
level=info ts=2021-11-01T08:46:30.728387509Z caller=module_service.go:59 msg=initialising module=ring
level=info ts=2021-11-01T08:46:30.728602596Z caller=ring.go:275 msg="ring doesn't exist in KV store yet"
level=info ts=2021-11-01T08:46:30.728725361Z caller=client.go:247 msg="value is nil" key=collectors/ring index=1
level=info ts=2021-11-01T08:46:30.728837683Z caller=module_service.go:59 msg=initialising module=querier
level=info ts=2021-11-01T08:46:30.728976203Z caller=worker.go:193 msg="adding connection" addr=127.0.0.1:9095
level=info ts=2021-11-01T08:46:30.731534998Z caller=module_service.go:59 msg=initialising module=overrides
level=info ts=2021-11-01T08:46:30.731603832Z caller=module_service.go:59 msg=initialising module=ingester
level=info ts=2021-11-01T08:46:30.731719203Z caller=module_service.go:59 msg=initialising module=distributor
level=info ts=2021-11-01T08:46:30.731761179Z caller=module_service.go:59 msg=initialising module=compactor
level=info ts=2021-11-01T08:46:30.73182886Z caller=tempodb.go:379 msg="polling enabled" interval=5m0s concurrency=50
level=info ts=2021-11-01T08:46:30.732185809Z caller=compactor.go:101 msg="waiting for compaction ring to settle" waitDuration=1m0s
level=info ts=2021-11-01T08:46:30.732375293Z caller=ingester.go:321 msg="beginning wal replay"
ts=2021-11-01T08:46:30Z level=info msg="No sampling strategies provided or URL is unavailable, using defaults" component=tempo
ts=2021-11-01T08:46:30Z level=info msg="Starting GRPC server on endpoint 0.0.0.0:4317" component=tempo
ts=2021-11-01T08:46:30Z level=info msg="Setting up a second GRPC listener on legacy endpoint 0.0.0.0:55680" component=tempo
ts=2021-11-01T08:46:30Z level=info msg="Starting GRPC server on endpoint 0.0.0.0:55680" component=tempo
ts=2021-11-01T08:46:30Z level=info msg="Starting HTTP server on endpoint 0.0.0.0:4318" component=tempo
level=info ts=2021-11-01T08:46:30.732892945Z caller=ingester.go:345 msg="wal replay complete"
level=info ts=2021-11-01T08:46:30.732980635Z caller=ingester.go:359 msg="reloading local blocks" tenants=0
level=info ts=2021-11-01T08:46:30.733098856Z caller=lifecycler.go:530 msg="not loading tokens from file, tokens file path is empty"
level=info ts=2021-11-01T08:46:30.733193106Z caller=app.go:251 msg="Tempo started"
level=info ts=2021-11-01T08:46:30.733308404Z caller=lifecycler.go:559 msg="instance not found in ring, adding with no tokens" ring=ingester
level=info ts=2021-11-01T08:46:30.733491435Z caller=lifecycler.go:406 msg="auto-joining cluster after timeout" ring=ingester
level=info ts=2021-11-01T08:47:30.733746155Z caller=compactor.go:103 msg="enabling compaction"
level=info ts=2021-11-01T08:47:30.733802195Z caller=tempodb.go:359 msg="compaction and retention enabled."
Tempo query:
2021/11/01 08:46:35 maxprocs: Leaving GOMAXPROCS=4: CPU quota undefined
{"level":"info","ts":1635756395.4116976,"caller":"flags/service.go:117","msg":"Mounting metrics handler on admin server","route":"/metrics"}
{"level":"info","ts":1635756395.4117658,"caller":"flags/service.go:123","msg":"Mounting expvar handler on admin server","route":"/debug/vars"}
{"level":"info","ts":1635756395.4120743,"caller":"flags/admin.go:121","msg":"Mounting health check on admin server","route":"/"}
{"level":"info","ts":1635756395.4121535,"caller":"flags/admin.go:127","msg":"Starting admin HTTP server","http-addr":":16687"}
{"level":"info","ts":1635756395.4121768,"caller":"flags/admin.go:113","msg":"Admin server started","http.host-port":"[::]:16687","health-status":"unavai
lable"}
{"level":"info","ts":1635756395.4386072,"caller":"grpc@v1.29.1/clientconn.go:243","msg":"parsed scheme: \"\"","system":"grpc","grpc_log":true}
{"level":"info","ts":1635756395.4387138,"caller":"grpc@v1.29.1/clientconn.go:249","msg":"scheme \"\" not registered, fallback to default scheme","system
{"level":"info","ts":1635756395.4387798,"caller":"grpc@v1.29.1/resolver_conn_wrapper.go:143","msg":"ccResolverWrapper: sending update to cc: {[{unused
0 }] }","system":"grpc","grpc_log":true}
{"level":"info","ts":1635756395.4388123,"caller":"grpc@v1.29.1/clientconn.go:667","msg":"ClientConn switching balancer to \"pick_first\"","system":"grpc
","grpc_log":true}
{"level":"info","ts":1635756395.4388225,"caller":"grpc@v1.29.1/clientconn.go:682","msg":"Channel switches to new LB policy \"pick_first\"","system":"grp
c","grpc_log":true}
{"level":"info","ts":1635756395.438887,"caller":"grpc@v1.29.1/clientconn.go:1056","msg":"Subchannel Connectivity change to CONNECTING","system":"grpc","
grpc_log":true}
{"level":"info","ts":1635756395.438935,"caller":"grpc/factory.go:79","msg":"External plugin storage configuration","configuration":{"PluginBinary":"/tmp
/tempo-query","PluginConfigurationFile":"/conf/tempo-query.yaml","PluginLogLevel":"warn"}}
{"level":"info","ts":1635756395.4390037,"caller":"grpc@v1.29.1/clientconn.go:1193","msg":"Subchannel picks a new address \"unused\" to connect","system"
{"level":"info","ts":1635756395.439275,"caller":"grpc@v1.29.1/clientconn.go:881","msg":"blockingPicker: the picked transport is not ready, loop back to
repick","system":"grpc","grpc_log":true}
{"level":"info","ts":1635756395.4393234,"caller":"grpc@v1.29.1/clientconn.go:881","msg":"blockingPicker: the picked transport is not ready, loop back to
{"level":"info","ts":1635756395.4395618,"caller":"grpc@v1.29.1/clientconn.go:417","msg":"Channel Connectivity change to CONNECTING","system":"grpc","grp
c_log":true}
{"level":"info","ts":1635756395.4399667,"caller":"grpc@v1.29.1/clientconn.go:1056","msg":"Subchannel Connectivity change to READY","system":"grpc","grpc
_log":true}
{"level":"info","ts":1635756395.439994,"caller":"grpc@v1.29.1/clientconn.go:417","msg":"Channel Connectivity change to READY","system":"grpc","grpc_log"
:true}
{"level":"info","ts":1635756395.4416337,"caller":"querysvc/query_service.go:137","msg":"Archive storage not created","reason":"archive storage not suppo
rted"}
{"level":"info","ts":1635756395.4416702,"caller":"app/flags.go:143","msg":"Archive storage not initialized"}
{"level":"info","ts":1635756395.4422145,"caller":"app/server.go:163","msg":"Query server started","port":16686,"addr":":16686"}
{"level":"info","ts":1635756395.442267,"caller":"healthcheck/handler.go:128","msg":"Health Check state change","status":"ready"}
{"level":"info","ts":1635756395.442288,"caller":"app/server.go:232","msg":"Starting CMUX server","port":16686,"addr":":16686"}
{"level":"info","ts":1635756395.4423287,"caller":"app/server.go:208","msg":"Starting HTTP server","port":16686,"addr":":16686"}
{"level":"info","ts":1635756395.4423535,"caller":"app/server.go:221","msg":"Starting GRPC server","port":16686,"addr":":16686"}
How can I check if Tempo can store the traces in S3?
Also I don’t know if I’m using the right port for Tempo and Grafana:
Tempo Query is only required by Grafana 7.4.x and before. This can probably be ignored.
The helm chart defaults to port 3100:
https://github.com/grafana/helm-charts/tree/main/charts/tempo (search for httpListenPort)
and you can see our example config here:
This is hopefully just a configuration issue between Grafana and Tempo. Try the 3100 port and see how it goes.
After running Tempo for a bit you can just check the configured bucket to see if it has created any blocks. You can also start Tempo with --distributor.log-received-traces and it will log all the traces it receives. This can be a quick way to confirm ingestion is working.
Also here are general purpose troubleshooting docs:
Thank you for answering my questions. I have checked the Prometheus metrics and they return numbers > 0
tempo_ingester_traces_created_total{container="tempo", endpoint="tempo-prom-metrics", instance="10.0.0.10:3100", job="tempo", namespace="monitoring", pod="tempo-0", service="tempo", tenant="single-tenant"}
12
and
tempo_distributor_spans_received_total{container="tempo", endpoint="tempo-prom-metrics", instance="10.0.0.10:3100", job="tempo", namespace="monitoring", pod="tempo-0", service="tempo", tenant="single-tenant"}
For accessing Tempo via Grafana, I changed tempo.monitoring.svc.cluster.local:3100 to tempo:3100 and no errors present anymore. However, the Minio bucket is still empty, so no traces are stored in it.
Tempo stores traces in memory and on disk until a certain threshold is reached at which point it cuts a block and pushes it to Minio. It’s possible this just hasn’t happened yet.
See max_block_bytes and max_block_duration for ways to reduce the threshold on cutting blocks:
Also you can check Tempo’s filesystem to see if there are wal files in /var/tempo/wal.
