Tempo provisioning with custom query does unintended replacement of values
    grafana:9.4.7, Ubuntu 22.04
    Provisioning Grafana Tempo with a custom query to enable traces to logs.
    I prepared a yaml file to provision the tempo data source.
  • What happened?
    The data source is initialized but the custom query field is not set correctly. Tokens like ${__tags} and ${__trace.traceId} might be being interpreted as environment variables which causes them to be replaced by empty strings.
    For the fields to not get replaced while they are being put to the custom query section.
    This is the config I’m using:
tracesToLogsV2:
        datasourceUid: 'rmH_crCVz'
        spanStartTimeShift: '1h'
        spanEndTimeShift: '-1h'
        tags: [ { key: "service.name", value: "job"} ]
        filterByTraceID: false
        filterBySpanID: false
        customQuery: true
        query: '{${__tags}} | json | traceid ="${__trace.traceId}" and spanid ="${__span.spanId}"'
    No errors, I can see the resulting custom query which is wrong.
    Grafana tempo provisioning docs
I can’t seem to find a way to escape these sequences, what should I do?
