The alert is not appearing
I have the following problem, every time I select another dashboard other than Graph, the menu to set up the alert disappears, would anyone know to tell me why this happens?
I am using version 7.5.3, as you can see in the images only the Grapy dashboard that appears the option to configure the alert, all others do not appear
Hi @gabrieliclubs,
Sorry for the confusion. Currently, only the graph panel supports alert rules.
Okay, could you give me a suggestion on how to improve the design of Graph?
So that it looks like the one in the attached image
The image is from the older version of Grafana. Currently, the graph editing view looks slightly different. You can learn more about editing/improving your graph in the documentation:
Also, you can visit grafana.play.org to see applied settings to different (not only) graph panels.
