Time Axis Does Not Line Up With Data
Hi Everyone,
Hopefully someone can answer this, I am confused. I have two queries producing two series. The data comes out of SQL as such:
The plot is correct however the columns/lines/dots do not line up correctly with the X axis labels.
It is also plotting data for 11/30 however my query does not have any data for 11/30. It is also showing times one X axis and in the tooltip when there are no times associated with the data.
Can anyone shed some light on what I might be doing wrong?
Thanks in advance!
Hi All,
I figured it out I think. My time column did not return a time so everything was plotted at midnight which made it look like was off a day.
I added 8 hours to the returned date and now the data looks much better and makes sense.
I wanted to update this incase anyone has the same question.
