I want to use Microsoft SQL DataSource and create a time graph to plot total rows for each hour.
My data:
StatId,TaskId,ClusterName,JobSeqName,RunName,JobName,TaskName,SystemName,InstallationFolder ,Duration,ExecutionStatus,SvaFinishedTime,LastChanged
1,20601,SCT_Run,testen,IsilonCheck,testen,testen,abts5333,abts5333_C:\temp,61,Finished,02-07-18 12:27:00.210,02-07-18 12:27:00.240
2,20602,SCT_Run,testen,IsilonCheck,testen,testen,abts5333,abts5333_C:\temp,61,Finished,02-07-18 12:28:01.710,02-07-18 12:28:01.710
3,20603,SCT_Run,testen,IsilonCheck,testen,testen,abts5333,abts5333_C:\temp,60,Finished,02-07-18 12:29:02.930,02-07-18 12:29:02.930
4,20604,SCT_Run,testen,IsilonCheck,testen,testen,abts5333,abts5333_C:\temp,61,Finished,02-07-18 12:30:04.167,02-07-18 12:30:04.167
5,20605,SCT_Run,testen,IsilonCheck,testen,testen,abts5333,abts5333_C:\temp,0,Failed,02-07-18 12:31:05.277,02-07-18 12:31:05.277
6,20606,SCT_Run,testen,IsilonCheck,testen,testen,abts5333,abts5333_C:\temp,60,Finished,02-07-18 12:32:06.560,02-07-18 12:32:06.573
7,20607,SCT_Run,testen,IsilonCheck,testen,testen,abts5333,abts5333_C:\temp,60,Finished,02-07-18 12:33:07.873,02-07-18 12:33:07.887
8,20608,SCT_Run,testen,IsilonCheck,testen,testen,abts5333,abts5333_C:\temp,0,Failed,02-07-18 12:34:09.107,02-07-18 12:34:09.123
9,20609,SCT_Run,testen,IsilonCheck,testen,testen,abts5333,abts5333_C:\temp,61,Finished,02-07-18 12:35:40.063,02-07-18 12:35:40.077
10,20610,SCT_Run,testen,IsilonCheck,testen,testen,abts5333,abts5333_C:\temp,60,Finished,02-07-18 12:36:41.250,02-07-18 12:36:41.267
11,20611,SCT_Run,testen,IsilonCheck,testen,testen,abts5333,abts5333_C:\temp,60,Finished,02-07-18 12:37:42.313,02-07-18 12:37:42.313
12,20612,SCT_Run,testen,IsilonCheck,testen,testen,abts5333,abts5333_C:\temp,0,Failed,02-07-18 12:38:18.987,02-07-18 12:38:18.987
My query:
SELECT
__timeEpoch(SvaFinishedTime), (SELECT Count(*) FROM [DB_SVA_TEST_SQL].[dbo].[StatisticSet] WHERE RunName = ‘IsilonCheck’ AND ExecutionStatus = ‘Finished’) as value, InstallationFolder as metric FROM [DB_TEST_SQL].[dbo].[StatisticSet] WHERE __timeFilter(SvaFinishedTime)
ORDER BY SvaFinishedTime ASC
