want to execute a query with upper and lower date limit.
Example a query which gives me all the records between two dates and these dates should be dynamically taken from date picket option available in grafana and this query is against a table in sql server
The date picker lets you select the range you want, so I still don’t understand what is different to the normal operation of the panel. Are you talking about the Graph panel?
