Time Series: Bars become unexpectedly thin for the same time points
I have noticed a weird behavior of the time series panel.
I have a simple query, weekly time points with some numeric series, generated by a postgres query. When I create the Time Series panel it works perfectly, as expected:
I copied the query (to ensure the time points are the same), modified the metric values and renamed the metric1 to metric2. Once I run it, suddenly the bars become extremely thin and for some reason the last data point is colored wrong.
Anyone knows how to fix this?
Key Value
Panel timeseries @ 9.3.8 (7ab70dbce8)
Grafana 9.3.8 (7ab70dbce8) // Open Source
Panel debug snapshot dashboard
  "panels": [
      "id": 2,
      "gridPos": {
        "h": 13,
        "w": 15,
        "x": 0,
        "y": 0
      "type": "timeseries",
      "title": "Reproduced with embedded data",
      "datasource": {
        "type": "grafana",
        "uid": "grafana"
      "fieldConfig": {
        "defaults": {
          "custom": {
            "drawStyle": "bars",
            "lineInterpolation": "linear",
            "barAlignment": 0,
            "lineWidth": 0,
            "fillOpacity": 100,
            "gradientMode": "none",
            "spanNulls": false,
            "showPoints": "auto",
            "pointSize": 5,
            "stacking": {
              "mode": "normal",
              "group": "A"
            "axisPlacement": "auto",
            "axisLabel": "",
            "axisColorMode": "text",
            "scaleDistribution": {
              "type": "linear"
            "axisCenteredZero": false,
            "hideFrom": {
              "tooltip": false,
              "viz": false,
              "legend": false
            "thresholdsStyle": {
              "mode": "off"
          "color": {
            "mode": "palette-classic"
          "mappings": [],
          "thresholds": {
            "mode": "absolute",
            "steps": [
                "color": "green",
                "value": null
                "color": "red",
                "value": 80
        "overrides": []
      "options": {
        "tooltip": {
          "mode": "single",
          "sort": "none"
        "legend": {
          "showLegend": true,
          "displayMode": "list",
          "placement": "bottom",
          "calcs": []
      "targets": [
          "refId": "A",
          "datasource": {
            "type": "grafana",
            "uid": "grafana"
          "queryType": "snapshot",
          "snapshot": [
              "schema": {
                "refId": "A",
                "meta": {
                  "executedQueryString": "SELECT * FROM (\r\n  VALUES\r\n    (1, '2023-04-23 00:00:00'::TIMESTAMP),\r\n    (3, '2023-04-30 00:00:00'::TIMESTAMP),\r\n    (10, '2023-05-07 00:00:00'::TIMESTAMP),\r\n    (5, '2023-05-14 00:00:00'::TIMESTAMP)\r\n  ) AS s(metric1, time)\r\n"
                "fields": [
                    "name": "metric1",
                    "type": "number",
                    "typeInfo": {
                      "frame": "int32",
                      "nullable": true
                    "config": {}
                    "name": "time",
                    "type": "time",
                    "typeInfo": {
                      "frame": "time.Time",
                      "nullable": true
                    "config": {}
              "data": {
                "values": [
                    1,
                    3,
                    10,
                    5
                    1682208000000,
                    1682812800000,
                    1683417600000,
                    1684022400000
              "schema": {
                "refId": "B",
                "meta": {
                  "executedQueryString": "SELECT * FROM (\r\n  VALUES\r\n    (5, '2023-04-23 00:00:00'::TIMESTAMP),\r\n    (6, '2023-04-30 00:00:00'::TIMESTAMP),\r\n    (0, '2023-05-07 00:00:00'::TIMESTAMP),\r\n    (2, '2023-05-14 00:00:00'::TIMESTAMP)\r\n  ) AS s(metric2, time)\r\n"
                "fields": [
                    "name": "metric2",
                    "type": "number",
                    "typeInfo": {
                      "frame": "int32",
                      "nullable": true
                    "config": {}
                    "name": "time",
                    "type": "time",
                    "typeInfo": {
                      "nullable": true
                    "config": {}
              "data": {
                "values": [
                    5,
                    6,
                    0,
                    2
                    1682208000000,
                    1682812800000,
                    1683417600000,
                    1684022400000
      "gridPos": {
        "h": 7,
        "w": 9,
        "x": 15,
        "y": 0
      "id": 5,
      "options": {
        "content": "<table width=\"100%\">\n    <tr>\n      <th width=\"2%\">Panel</th>\n      <td >timeseries @ 9.3.8 (7ab70dbce8)</td>\n    </tr>\n    <tr>\n      <th>Queries</th>\n      <td>A[postgres], B[postgres]</td>\n    </tr>\n    \n    <tr><th>Data</th><td> 2 frames, 4 fields, 8 rows </td></tr>\n    \n    <tr>\n      <th>Grafana</th>\n      <td>9.3.8 (7ab70dbce8) // Open Source</td>\n    </tr>\n  </table>",
        "mode": "html"
      "title": "Debug info",
      "type": "text"
      "id": 6,
      "title": "Original Panel JSON",
      "type": "text",
      "gridPos": {
        "h": 13,
        "w": 9,
        "x": 15,
        "y": 7
      "options": {
        "content": "{\n  \"id\": 2,\n  \"gridPos\": {\n    \"h\": 16,\n    \"w\": 24,\n    \"x\": 0,\n    \"y\": 0\n  },\n  \"type\": \"timeseries\",\n  \"title\": \"Panel Title\",\n  \"datasource\": {\n    \"uid\": \"CNGEJGw7k\",\n    \"type\": \"postgres\"\n  },\n  \"fieldConfig\": {\n    \"defaults\": {\n      \"custom\": {\n        \"drawStyle\": \"bars\",\n        \"lineInterpolation\": \"linear\",\n        \"barAlignment\": 0,\n        \"lineWidth\": 0,\n        \"fillOpacity\": 100,\n        \"gradientMode\": \"none\",\n        \"spanNulls\": false,\n        \"showPoints\": \"auto\",\n        \"pointSize\": 5,\n        \"stacking\": {\n          \"mode\": \"normal\",\n          \"group\": \"A\"\n        },\n        \"axisPlacement\": \"auto\",\n        \"axisLabel\": \"\",\n        \"axisColorMode\": \"text\",\n        \"scaleDistribution\": {\n          \"type\": \"linear\"\n        },\n        \"axisCenteredZero\": false,\n        \"hideFrom\": {\n          \"tooltip\": false,\n          \"viz\": false,\n          \"legend\": false\n        },\n        \"thresholdsStyle\": {\n          \"mode\": \"off\"\n        }\n      },\n      \"color\": {\n        \"mode\": \"palette-classic\"\n      },\n      \"mappings\": [],\n      \"thresholds\": {\n        \"mode\": \"absolute\",\n        \"steps\": [\n          {\n            \"color\": \"green\",\n            \"value\": null\n          },\n          {\n            \"color\": \"red\",\n            \"value\": 80\n          }\n        ]\n      }\n    },\n    \"overrides\": []\n  },\n  \"options\": {\n    \"tooltip\": {\n      \"mode\": \"single\",\n      \"sort\": \"none\"\n    },\n    \"legend\": {\n      \"showLegend\": true,\n      \"displayMode\": \"list\",\n      \"placement\": \"bottom\",\n      \"calcs\": []\n    }\n  },\n  \"targets\": [\n    {\n      \"datasource\": {\n        \"type\": \"postgres\",\n        \"uid\": \"CNGEJGw7k\"\n      },\n      \"editorMode\": \"code\",\n      \"format\": \"table\",\n      \"hide\": false,\n      \"rawQuery\": true,\n      \"rawSql\": \"SELECT * FROM (\\r\\n  VALUES\\r\\n    (1, '2023-04-23 00:00:00'::TIMESTAMP),\\r\\n    (3, '2023-04-30 00:00:00'::TIMESTAMP),\\r\\n    (10, '2023-05-07 00:00:00'::TIMESTAMP),\\r\\n    (5, '2023-05-14 00:00:00'::TIMESTAMP)\\r\\n  ) AS s(metric1, time)\\r\\n\",\n      \"refId\": \"A\",\n      \"sql\": {\n        \"columns\": [\n          {\n            \"parameters\": [],\n            \"type\": \"function\"\n          }\n        ],\n        \"groupBy\": [\n          {\n            \"property\": {\n              \"type\": \"string\"\n            },\n            \"type\": \"groupBy\"\n          }\n        ],\n        \"limit\": 50\n      }\n    },\n    {\n      \"datasource\": {\n        \"type\": \"postgres\",\n        \"uid\": \"CNGEJGw7k\"\n      },\n      \"editorMode\": \"code\",\n      \"format\": \"table\",\n      \"hide\": false,\n      \"rawQuery\": true,\n      \"rawSql\": \"SELECT * FROM (\\r\\n  VALUES\\r\\n    (5, '2023-04-23 00:00:00'::TIMESTAMP),\\r\\n    (6, '2023-04-30 00:00:00'::TIMESTAMP),\\r\\n    (0, '2023-05-07 00:00:00'::TIMESTAMP),\\r\\n    (2, '2023-05-14 00:00:00'::TIMESTAMP)\\r\\n  ) AS s(metric2, time)\\r\\n\",\n      \"refId\": \"B\",\n      \"sql\": {\n        \"columns\": [\n          {\n            \"parameters\": [],\n            \"type\": \"function\"\n          }\n        ],\n        \"groupBy\": [\n          {\n            \"property\": {\n              \"type\": \"string\"\n            },\n            \"type\": \"groupBy\"\n          }\n        ],\n        \"limit\": 50\n      }\n    }\n  ]\n}",
        "mode": "code",
        "code": {
          "language": "json",
          "showLineNumbers": true,
          "showMiniMap": true
      "id": 3,
      "title": "Data from panel above",
      "type": "table",
      "datasource": {
        "type": "datasource",
        "uid": "-- Dashboard --"
      "gridPos": {
        "h": 7,
        "w": 15,
        "x": 0,
        "y": 13
      "options": {
        "showTypeIcons": true
      "targets": [
          "datasource": {
          "panelId": 2,
          "withTransforms": true,
          "refId": "A"
  "schemaVersion": 37,
  "title": "Debug: Panel Title // 2023-04-13 21:33:34",
  "tags": [
    "debug",
    "debug-timeseries"
  "time": {
    "from": "2023-03-31T22:00:00.000Z",
    "to": "2023-05-31T21:59:59.000Z"
