v9.1.1 (9e60a1bff1) on Linux, using the official Docker image.
We display time series data.
We use the time based line chart. We retrieve the data from a REST API that we connect to using the Infinity Datasource Plugin. We process the data in Grafana with UQL.
What happened?
The connection between two points does not work as indicated in the screenshot above. In particular, the data point of October 21 is not recognized as point of the time series. It is neither connected to the rest of the time series nor can we hover over it to investigate its value.
Nevertheless, the time-series data is consistent. We have one data point for each day - also for October 21. We have checked that by displaying the data in tabular format.
We expect Grafana to recognize all data points as part of the time series. How the chart should be displayed is indicated by the red line in the screenshot above.
No configuration to be shown.
No errors in the Grafana UI or logs.
Did you follow any online instructions? If so, what is the URL?
No online instructions.
