TLS skip verify for generic OAuth
I have KeyCloak identity server that is running with non-production certificate so far. I would like to connect Grafana’s OAuth to it but it complains because of TLS verification. I have found there is a flag to overcome it.
I have set GF_AUTH_GENERIC_OAUTH_TLS_SKIP_VERIFY_INSECURE=true but it seems the variable is not taken at the beginning, other generic OAuth variables are.
I use following version:
t=2018-07-28T07:22:10+0000 lvl=info msg="Starting Grafana" logger=server version=5.2.2 commit=aeaf7b2 compiled=2018-07-25T11:17:28+0000
I can also see multiple values being overriden:
t=2018-07-28T07:22:10+0000 lvl=info msg="Config overridden from Environment variable" logger=settings var="GF_AUTH_GENERIC_OAUTH_ENABLED=true"
Is there a bug or I am doing something wrong?
Thank you for help.
I guess, it’s not implemented. Did you find it in the documentation?
I found it in the code :slight_smile: And it was merged in October 2017…
https://github.com/grafana/grafana/blob/master/pkg/social/social.go
So probably I am missing something…
You are right. It looks like a bug. Config option is missing in conf/defaults.ini, so you can’t override it with env variable.
if that is the only thing, I can create pull request for that, but I am not a Go developer yet :slight_smile: I will report an issue along.
