I am trying to develop a mobile application that will display Grafane web pages and panels in the application. I use android WebView. It displays other web pages but when it comes to Grafana it gives below warning.
If you’re seeing this Grafana has failed to load its application files
- This could be caused by your reverse proxy settings.
- If you host grafana under subpath make sure your grafana.ini root_url setting includes subpath. If not using a reverse proxy make sure to set serve_from_sub_path to true.
- If you have a local dev build make sure you build frontend using: yarn start, yarn start:hot, or yarn build
- Sometimes restarting grafana-server can help
There is no proxy configured. Grafana serves web with its default webserver.
I can embed grafana web pages to another web sites with iframes without problem.
But it gives above error when trying to embed grafana web pages or panels in android webviev.
I can add other web pages from different web sites to android webview and it is displaying. But when i put a panel with iframe in those web sites pages, again those pages are giving same warning for grafana added iframe parts. I dont use any proxy, just pure grafana installation with grafana server.
