Trying to package: Webpack never ends
Hi, I’m trying to build a custom grafana for a raspberry pi. I’ve forked the source code.
I’m doing:
go run build.go -goarch armv7 -cc arm-linux-gnueabihf-gcc build
yarn install --pure-lockfile --no-progress
go run build.go build-frontend
And building front end just shows
Running "exec:webpack" (exec) task
Starting type checking service...
Using 1 worker with 2048MB memory limit
But it never ends.
Same result if I ran directly
 go run build.go -goos linux -pkg-arch armv7 package-only
or
go run build.go -goos linux -pkg-arch armv7 pkg-deb
I tried erasing the node_modules folder and retrying again with no luck of any of those three methods.
Grafana version: 6.5.3
Node version: 10.18.1
PS: If I just try to develop and run grafana with yarn install --pure-lockfile and make run, it works on my machine apparently with no issues.
Building on a Pi I had problems with phantomjs, have those been sorted? This prevented me building the package on a pi though I was able to build and run locally by removing the phantomjs-prebuilt line from package.json.
I don’t understand the full subtleties of what I am doing, but when I build a package on Ubuntu I just run
go run build.go build package
which works on Ubuntu, but as I said not on a pi due, if I remember correctly, to the phantomjs problem.
Hi, thanks for your answer. Note that I’m crosscompiling, not compiling directly in the Pi.
PS: Not sure about what you said, but I’ll check if phantomjs is an issue for the building process.
Oh yes. I tried that briefly but didn’t manage it so build on the pi instead. It takes a long, long time on a Pi 3, not so bad on a 4. You can run the files from a 4 build on a 3.
Found a hint looking at the grafana issues
So the process I end up using for generating a deb package for the pi was (crosscompiling):
yarn dev
go run build.go -goos linux -pkg-arch armv7 -skipRpm package-only
If that works for me too I shall be eternally grateful.
Perhaps something could be added to the wiki somewhere.
