I am hoping I can have a few pointers as I’m a bit stuck!
I am trying to setup grafana so I can monitor our network, I have installed grafana fine, but I’m a bit lost from the data store perspective. I’m assuming I now need to download a data source first and the have some way of pulling in snmp information from the network to the influxdb, but I’m not sure how to do this.
I’m running on windows, and haven’t installed a data source yet. Do any come as part of the install?
Sorry for the long post I’m just trying to figure out the next steps to get the data into the data source!
To get your SNMP data into InfluxDB, you are going to need an agent (called a collector) that will gather the data and then write it to your InfluxDB. InfluxDB has its own collector called Telegraf. Here is a getting started guide. There is an snmp plugin for Telegraf that you will need to install and configure to write the correct data to InfluxDB. See here for details.
This dashboard is specific to Huawei hardware but could you give some ideas about how a dashboard can look.
