looking at newest -
visualize very large opentelemetry traces -
that’s the question -
What happened?
Did you follow any online instructions? If so, what is the URL?
The documentation is pretty sparse for trace viewing
I am looking to add jaeger tracing to one of our complex systems. It will produce thousands of span, significant depth and takes as much as 45 minutes to run. To explore this I need a few functions from the trace explore UI that I don’t see today. I am new to this so they may be there and I just don’t know how to do it.
- be able to interactively turn off displaying spans other than the one of current interest and its children. This or something similar will be needed to tame the amount of data presented. Same in the graph view would also be great.
- (nice to have) be able to set the default number of layers to expand and visualize when a trace is loaded. With thousands of spans, it will be unreadable if it loads with everything open. It will take many clicks to get it to a readable state.
