Unable to display multi server information using status panel using Grafana + Prometheus
    Grafana Version: 9.3.2
    Data Source: Prometheus
    Exporte: Blackbox Exporter
We want to display multiple targets(websites) information received from blackbox exporter using status panel
    We are trying to implement status panel but getting below error when i tried to add more than one query
  • What happened?
Note: Every metric has to have a unique Alias to be used
    Grafana Queries
Status Panel plugin for Grafana | Grafana Labs - followed these instructions and
Challenge: we are facing is unable to give alias name also
Hi @reachsatish91,
Welcome to the :grafana: community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community :slight_smile:
I have moved this post to the Prometheus category as it seems more relevant.
Though I do not have much information about Prometheus, I looked into your case and it seems that the Status Panel is a community plugin and we do not take ownership of it.
I would suggest checking their GitHub page and checking the reported issues if this incase this is a known issue or solved with a working solution or workaround.
Hopefully, someone in the community will able to help you further :slight_smile:
