Hi. I’m having hard times understanding what the output from test run means.
Text output is follows similar format as the command-line, however there are all sorts of characters added rendering it useless
Below is the text copy-paste
2022-04-20T23:04:00.7631530Z e[31m ✗ status is 200
2022-04-20T23:04:00.7631849Z ↳ 0% — ✓ 0 / ✗ 2391e[0m
2022-04-20T23:04:00.7632156Z e[31m ✗ res body contains items
2022-04-20T23:04:00.7632394Z ↳ 0% — ✓ 0 / ✗ 2391e[0m
2022-04-20T23:04:00.7632493Z
2022-04-20T23:04:00.7632684Z █ setup
2022-04-20T23:04:00.7632768Z
2022-04-20T23:04:00.7632964Z e[32m ✓ status is 200e[0m
2022-04-20T23:04:00.7633310Z e[32m ✓ res body contains accessTokene[0m
2022-04-20T23:04:00.7633492Z
2022-04-20T23:04:00.7634279Z e[31m✗e[0m GetMenus_Duratione[2m..............:e[0m avg=e[36m909.002426e[0m min=e[36m76.8148e[0m med=e[36m761.8644e[0m max=e[36m2914.4075e[0m p(90)=e[36m1692.4524e[0m p(95)=e[36m2007.45595e[0m p(99)=e[36m2559.98371e[0m count=e[36m2391e[0m
2022-04-20T23:04:00.7635003Z e[31m✗e[0m GetMenus_Requestse[2m..............:e[0m e[36m0.00%e[0m e[36;2m✓ 0e[0m e[36;2m✗ 2391e[0m
2022-04-20T23:04:00.7635444Z checkse[2m.........................:e[0m e[36m0.04%e[0m e[36;2m✓ 2e[0m e[36;2m✗ 4782e[0m
2022-04-20T23:04:00.7635833Z data_receivede[2m..................:e[0m e[36m1.2 MBe[0m e[36;2m19 kB/se[0m
2022-04-20T23:04:00.7636225Z data_sente[2m......................:e[0m e[36m405 kBe[0m e[36;2m6.8 kB/se[0m
2022-04-20T23:04:00.7636799Z http_req_blockede[2m...............:e[0m avg=e[36m6.33mse[0m min=e[36m0se[0m med=e[36m0se[0m max=e[36m121.84mse[0m p(90)=e[36m0se[0m p(95)=e[36m76.76mse[0m p(99)=e[36m82.52mse[0m count=e[36m2392e[0m
2022-04-20T23:04:00.7637611Z http_req_connectinge[2m............:e[0m avg=e[36m2.12mse[0m min=e[36m0se[0m med=e[36m0se[0m max=e[36m68.69mse[0m p(90)=e[36m0se[0m p(95)=e[36m25.17mse[0m p(99)=e[36m27.64mse[0m count=e[36m2392e[0m
2022-04-20T23:04:00.7638384Z http_req_duratione[2m..............:e[0m avg=e[36m908.67mse[0m min=e[36m76.81mse[0m med=e[36m761.72mse[0m max=e[36m2.91se[0m p(90)=e[36m1.69se[0m p(95)=e[36m2se[0m p(99)=e[36m2.55se[0m count=e[36m2392e[0m
2022-04-20T23:04:00.7639216Z { expected_response:true }e[2m...:e[0m avg=e[36m131.27mse[0m min=e[36m131.27mse[0m med=e[36m131.27mse[0m max=e[36m131.27mse[0m p(90)=e[36m131.27mse[0m p(95)=e[36m131.27mse[0m p(99)=e[36m131.27mse[0m count=e[36m1e[0m
2022-04-20T23:04:00.7639849Z http_req_failede[2m................:e[0m e[36m99.95%e[0m e[36;2m✓ 2391e[0m e[36;2m✗ 1e[0m
2022-04-20T23:04:00.7640586Z http_req_receivinge[2m.............:e[0m avg=e[36m157.84µse[0m min=e[36m0se[0m med=e[36m0se[0m max=e[36m2.11mse[0m p(90)=e[36m670.62µse[0m p(95)=e[36m916.35µse[0m p(99)=e[36m1.02mse[0m count=e[36m2392e[0m
2022-04-20T23:04:00.7641454Z http_req_sendinge[2m...............:e[0m avg=e[36m34.17µse[0m min=e[36m0se[0m med=e[36m0se[0m max=e[36m1.95mse[0m p(90)=e[36m160.11µse[0m p(95)=e[36m232.26µse[0m p(99)=e[36m533.68µse[0m count=e[36m2392e[0m
2022-04-20T23:04:00.7642252Z http_req_tls_handshakinge[2m.......:e[0m avg=e[36m4.19mse[0m min=e[36m0se[0m med=e[36m0se[0m max=e[36m86.24mse[0m p(90)=e[36m0se[0m p(95)=e[36m51.13mse[0m p(99)=e[36m54.69mse[0m count=e[36m2392e[0m
2022-04-20T23:04:00.7643025Z http_req_waitinge[2m...............:e[0m avg=e[36m908.48mse[0m min=e[36m76.59mse[0m med=e[36m760.93mse[0m max=e[36m2.91se[0m p(90)=e[36m1.69se[0m p(95)=e[36m2se[0m p(99)=e[36m2.55se[0m count=e[36m2392e[0m
2022-04-20T23:04:00.7644529Z http_reqse[2m......................:e[0m e[36m2392e[0m e[36;2m39.862158/se[0m
2022-04-20T23:04:00.7645114Z iteration_duratione[2m.............:e[0m avg=e[36m2.39se[0m min=e[36m304.94mse[0m med=e[36m2.32se[0m max=e[36m4.75se[0m p(90)=e[36m3.19se[0m p(95)=e[36m3.52se[0m p(99)=e[36m4.07se[0m count=e[36m2322e[0m
2022-04-20T23:04:00.7645705Z iterationse[2m.....................:e[0m e[36m2321e[0m e[36;2m38.678958/se[0m
2022-04-20T23:04:00.7646105Z vuse[2m............................:e[0m e[36m198e[0m e[36;2mmin=3e[0m e[36;2mmax=198e[0m
2022-04-20T23:04:01.1067725Z vus_maxe[2m........................:e[0m e[36m300e[0m e[36;2mmin=300e[0m e[36;2mmax=300e[0mtime="2022-04-20T23:04:01Z" level=error msg="some thresholds have failed"
