Unspecified Error when trying to connect to an Elasticsearch (Zammad) instance in Data Sources
    Grafana : 8.1.2
    Debian: Buster
    Trying to connect to an Elasticsearch (Zammad) Data Source on another server
    HTTP
    URL: http://helpdesk.ddomain.com:9200
    Access: Server (default)
Elasticsearch details
Index name: zammad_production_ticket
Pattern: No pattern
Time field name: created_at
Version: 7.10+
Max concurrent Shard Requests: 5
Min time interval: 10s
X-Pack enabled: yes
Include frozen indices: yes
Everything else is default.
  • What happened?
    Elasticsearch error: Unexpected error
    A connection to the Elasticsearch instance.
    See above.
    Nothing obvious in any logs.
    Elasticsearch | Grafana documentation
Any and all assistance is appreciated.
Figured out the issue and now have data sources connected.
