Hi, grafana is very powerful and useful! We’re customizing dashboard these days, but find that it’s hard to debug backend server codes, because of following scenes:
Develop with command:
make run
Grafana would watch codes and build a ‘grafana-server.exe’ to execute server. If codes modified(for example, add a log for debugging), grafana will rebuild a ‘gafana-server.exe’ to execute server, but the time takes about 30 seconds, which are too long(on windows, computer’s hardware performance is also high enough) -
go run pkg/cmd/grafana-server/main.go
directly:
With no luck, errors threw.
But if there’s a way to run server codes directly(without generating a grafana-server.exe
), we’re able to debug server codes even using breakpoints like this:
Can you provide a guide about how to debugg backend server codes directly? Or can you tell us how your team debug the server codes?
Grafana version: 7.4.0-pre
Thank you!
