Hi, the current architecture of multi-tenant Loki is a directory for each tenant ID under the existing bucket if we are using s3 backend storage.
Is there a way to configure the Loki to create a bucket for each tenant instead of using directories per bucket? (multi bucket option)
The problem is
Under multi-tenant architecture, there should be a way to monitor the space usage of each tenant with consideration of the retention time configuration.Hi, the current architecture of multi-tenant Loki is a directory for each tenant ID under the existing bucket if we are using s3 backend storage.
The problem is
