I wanted to use alias by InstanceName so that I can populate instance names instead of instance ids in the legend.
I tried using Instance Names in dimensions instead of instance ids but that is not supported by AWS.
Is there a way I can access the corresponding instance name instead of instance id.
So the issue is I wanted to know if there is a way I can do that.
I can suggest a new field below dimensions where we can store tags corresponding to that instance id and store instance names there which we can later use in the Alias
