What Grafana version and what operating system are you using? v 9.4.3
What are you trying to achieve? I would like to use Grafanas timerange property in dashboard, based on which to get the count to a Bigquery database
How are you trying to achieve it?---->I use a query to Bigquery dataset select time, count(*) from ‘dataset.table’ where date(timeInterval)=current_date() group by time order by time. The result is displayed as a bar chart in a panel. The result contains for the current date.
What happened? I cant seem to find a way to pass the timerange property from Grafana dashboard(like past 6 hours, 3 hours etc) to my query instead of for the whole date? Is this even possible?
What did you expect to happen? —My expectation is to pass this range to my query if possible
Did you follow any online instructions? If so, what is the URL?
Hello @fetolicij
Can you confirm that you using this plugin with Grafana to query your BigQuery data warehouse? If yes, then it appears all you need to do is change this:
to this:
select time, count(*) from ‘dataset.table’ WHERE $__timeFilter(time_column) group by time order by time
