__value and __text for variables not working as expected
    9.3.6 running on MacOS, datasource is using the BigQuery datasource from Grafana Labs version 1.2.4.
    Setup a variable with a value and a text field so that the text field is displayed but in the dashboard I can reference the value field in other sql.
    I am using the following SQL for the variable:
    SELECT DISTINCT
    ctx.Site AS __text,
    ctx.SiteID AS __value
    FROM contexts_v0.installation_context_v0 ctx
I have tested this SQL in BigQuery Explorer and it executes as I’d expect returning two columns with the appropriate names.
The variable is called varSiteId and I reference it using ${varSiteId}.
  • What happened?
    ${varSiteId} is being replaced with the name of the site (from __text) rather than the id (from __value).
    The site name to be displayed and ${varSiteId} to contain the (integer) id (for example “Test Site 01” would see “${varSiteId}” returning “21”.
    See above
    No visible errors.
    PostgreSQL data source | Grafana documentation
Welcome
What is the data type of the above column?
It’s an integer - does it need to be text?
no you dont, just try
${varSiteId:raw}
I just get the string value - the problem is it’s not correctly mapping the __text and __value columns.
However, if I put them in reverse order (__value and then __text) it works which is a fix … of a kind … probably still a bug that needs looking at though!
So in summary the SQL;
SELECT DISTINCT
ctx.SiteID AS __value,
ctx.Site AS __text
Works. But column ordering seems to be a real issue that I’m not sure is documented anywhere.
