I’ve found a regexp escaping issue when using Grafana + a MySQL datasource. Let’s assume a simple dashboard including a variable location
that can take one or more values: madrid
, london
or whatever(42)
. Using that value we can build the name of the metrics to be retrieved from the metrics
table (i.e. foo.madrid.value
, foo.london.value
, foo.whatever(42).value
, etc.). We want to do that using the REGEXP
SQL operator:
WHERE
metrics.name REGEXP '^foo\\.${location:regex}\\.value$'
If madrid
and london
are selected that SQL string will be expanded to ^foo\\.(madrid|london)\\.value$
. No problem with that. But if the value including the parentheses is selected, the SQL string will be expanded to ^foo\\.whatever\(42\)\\.value$
, which is not ok because in MySQL strings backslashes need to be double-escaped. In other words, a metric named foo.whatever42.value
would match the generated regexp string, but not foo.whatever(42).value
We’ve considered adding NO_BACKSLASH_ESCAPES
to sql_mode
before the query is executed and restore it to previous value just after that, but it’s ugly and I don’t think is even doable. Any tricks to workaround this?
