Variables not working for ES?
Hi ,
I am creating a datasource for ES successfully, however, I tried to create Variables(Tepmplate) from ES, but it does not successfully. could you please help me to understand what I did wrong ?
{“find”:“terms”,“field”:"@cluster"}
Preview of values (shows max 20)
None
ES version is v5.6
Thanks.
Check this thread, which might help:
https://localhost:3000/t/variable-query-doesnt-work/5675
Hi, I show you how I use them.
Thanks… keyword solved it. thanks for quick reply.
Thanks for the reply. keyword fixed it.
