Hi I’m doing performance testing and I’m able to open the web-socket and suscribe to the channel successfully.
But I’m facing the following issue to simulate user journey I need to perform some actions (HTTP requests) while the web socket is opened and then close the web-socket with a HTTP post request.
Is it possible to open the web socket and keep it alive in the background, so the k6 script can move on with the following HTTP requests that requiere that connection opened?
Thanks in advance you help will be much appreciatted.
Hi @uherzel,
Moving on with an open websocket is not possible as … k6 doesn’t have an event loop.
But you can make http requests … inside the websocket mini event loop. The catch is that if a part of the in websocket event loop is being executed no other part can execute, which might be a problem for you, but you have to check
A small example I adapted:
var http = require("k6/http");
var ws = require("k6/ws");
var check = require("k6").check;
exports.default = function () {
var url = "wss://echo.websocket.org"
var params = {};
var res = ws.connect(url, params, function (socket) {
socket.on('open', function open() {
var res = http.get("http://test.k6.io");
console.log(res.status);
socket.setInterval(function timeout() {
socket.send("test highload");
socket.ping();
}, 10);
socket.on('ping', function () {
socket.on('close', function() {
console.log("close");
socket.setTimeout(function () {
socket.close();
}, 2000);
check(res, { "status is 101": function(r) {return r && r.status === 101 }});
Will get you:
INFO[0000] 200
INFO[0002] close
done [==========================================================] 1 / 1
✓ status is 101
checks.....................: 100.00% ✓ 1 ✗ 0
data_received..............: 33 kB 13 kB/s
data_sent..................: 22 kB 8.7 kB/s
http_req_blocked...........: avg=184.17ms min=184.17ms med=184.17ms max=184.17ms p(90)=184.17ms p(95)=184.17ms
http_req_connecting........: avg=111.55ms min=111.55ms med=111.55ms max=111.55ms p(90)=111.55ms p(95)=111.55ms
http_req_duration..........: avg=113.06ms min=113.06ms med=113.06ms max=113.06ms p(90)=113.06ms p(95)=113.06ms
http_req_receiving.........: avg=261.97µs min=261.97µs med=261.97µs max=261.97µs p(90)=261.97µs p(95)=261.97µs
http_req_sending...........: avg=148.13µs min=148.13µs med=148.13µs max=148.13µs p(90)=148.13µs p(95)=148.13µs
http_req_tls_handshaking...: avg=0s min=0s med=0s max=0s p(90)=0s p(95)=0s
http_req_waiting...........: avg=112.65ms min=112.65ms med=112.65ms max=112.65ms p(90)=112.65ms p(95)=112.65ms
http_reqs..................: 1 0.397284/s
iteration_duration.........: avg=2.51s min=2.51s med=2.51s max=2.51s p(90)=2.51s p(95)=2.51s
iterations.................: 1 0.397284/s
vus........................: 1 min=1 max=1
vus_max....................: 1 min=1 max=1
ws_connecting..............: avg=516ms min=516ms med=516ms max=516ms p(90)=516ms p(95)=516ms
ws_msgs_received...........: 158 62.770919/s
ws_msgs_sent...............: 170 67.538331/s
ws_ping....................: avg=115.384028 min=111.638298 med=112.170248 max=174.721201 p(90)=117.069677 p(95)=137.421875
ws_session_duration........: avg=2.51s min=2.51s med=2.51s max=2.51s p(90)=2.51s p(95)=2.51s
ws_sessions................: 1 0.397284/s
You can even open another websocket inside the first one, but again you will block the outer one event loop until the inner one finishes, which might be what you want, but unlikely
