Where to download mimir-2.4 RPM
Grafana release page (Releases · grafana/mimir · GitHub) say there are RPM packages for mimir
like
64.rpm
Is this and/or future releases going to be available in Grafana OSS Repo:
here `https://packages.grafana.com/oss/rpm ?
Hi @marcinp,
As per the documentation it is defined here as how to download Mimir;
Though I haven’t yet played with Mimir but it seems that once you for e.g. add the helm repo, should list you the version 2.4.x (as the document is also linked with v.2.4.x)
I hope this helps.
Thanks Usman
You have missed the point I’m asking for standalone binary for Classic RHEL Linux and not container/kubernetes/hełm.
Hi Marcin,
Sorry that I misunderstood it.
Found a blog article as how to download Mimir locally and use it with it dependencies:
I will try to get our documentation team to check as whether is there a missing link to install locally as it only points to using Kubernetes or HELM.
Ah found it as it was there under “Get started”:
I hope this helps.
