I configured Prometheus Datasource behind of self-signed tls Nginx proxy.
I got the following error.
But it works if …
- checked
Skip TLS Verify
curl --cacert /root/ca.crt https://localhost
-https://localhost
is nginx endpoint.
My Configuration
- nginx.conf
$ cat /etc/Nginx/Nginx.conf
http {
log_format main '$remote_addr - $remote_user [$time_local] "$request" '
'$status $body_bytes_sent "$http_referer" '
'"$http_user_agent" "$http_x_forwarded_for" "$request_body"';
server {
listen 443 ssl;
server_name localhost;
ssl_certificate /root/server.crt;
ssl_certificate_key /root/server.key;
location / {
proxy_pass http://localhost:9090/;
events {}
- certifications
$ ln -s /root/ca.crt /root/"$(openssl x509 -hash -noout -in /root/ca.crt).0"
$ openssl verify -CApath /root /root/server.crt
/root/server.crt: OK
$ cat /root/ca.crt
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
