Hi guys can somebody help with this error?
Hi @badproxy
Welcome to the community forum
Can you share a bit more details:
- the (sanitized) script, for some EOF there is a workaround and I’d like to check if that’s the same case
- the elasticseach extension used.
- Do you see the EOF without the output, using just stdout?
- the command you use to run k6
- the results of
k6 version
so we can see the version you are using - full output of the test run, to double-check if there is anything else logged in the console
Thanks in advance for the additional info.
Cheers!
Hi, thanks for the reply, but I’ve decided to not use elastic anymore!
