Xk6 extension write to file build issue
Have installed GO and xk6 as mentioned in GitHub - grafana/xk6: Build k6 with extensions.
When tried to build xk6-file extension getting below error:
C:\Program Files\Go\bin>xk6 build --with github.com/avitalique/xk6-file@latest
2021/10/21 17:17:29 [INFO] Temporary folder: C:\Users\HanumHul\AppData\Local\Temp\buildenv_2021-10-21-1717.676274793
2021/10/21 17:17:29 [INFO] Writing main module: C:\Users\HanumHul\AppData\Local\Temp\buildenv_2021-10-21-1717.676274793\main.go
2021/10/21 17:17:29 [INFO] Initializing Go module
2021/10/21 17:17:29 [INFO] exec (timeout=10s): go.exe mod init k6
2021/10/21 17:17:29 [INFO] Cleaning up temporary folder: C:\Users\HanumHul\AppData\Local\Temp\buildenv_2021-10-21-1717.676274793
2021/10/21 17:17:29 [FATAL] exec: “C:\Users\HanumHul\AppData\Local\Temp\buildenv_2021-10-21-1717.676274793\go.exe”: file does not exist
I am looking to use extension xk6-file, want to write data to file.
Hi @huligesh.hanumanthap
This error indicates that something is off with your Golang installation:
Here go.exe was not found in local folder: but it must be in the PATH variable instead. It makes sense to check Golang binary location and PATH value on your machine.
