404 Page not found on Azure Data Explorer plugin webpage?
Hi there, I am seeing 404 Page not found | Grafana Labs
Any suggestions?
  • What happened?
welcome to the Grafana community forum :grafana: @RajEnterprise
thanks for reporting the broken link
can i ask you where did you find it so we can replace it with the proper one?
here is the link you were looking for : Azure Data Explorer Datasource plugin for Grafana | Grafana Labs
Thanks. I had it in the screenshot. Seems fixed now.
@antonio Could you also report&fix this issue, please:
Those “Settings” links use org name (e.g. Monitorng Artist) instead of org id (e.g. monitoringartist). It is there unnoticed for a few months.
I would recommend to analyse access logs and 404 responses - you may have a more 404 issues.
It looks like also when dashboard is not “approved” then “Details” link returns 404 response (UX :-().
thanks for bringing this up
i have reported this issue internally but since it’s cloud related, could you also please create a support ticket for it ?
thank you!
btw i also get the same 404 when clicking on Details regardless my org name contains no spaces and looks properly encoded
[EDIT]
i cannot longer repro the 404 but I have been informed that it 's a known issue, and that it is caused by the current publish-dashboards workflow running every x hours.
@antonio Another 404 error - old dashboard links don’t work anymore,
e.g.: https://grafana.com/dashboards/15983 → 404 - any old saved links from outside Grafana portal will be broken. I would expect 301 redirect to new format:
https://grafana.com/dashboards/15983 -> 301 Redirect to:
https://grafana.com/grafana/dashboards/15983-opentelemetry-collector/
:pray:
They should really have automated vetting process for this
@antonio Another 404 case is when older version of the plugin is unpublished (I have no idea why), e.g. https://grafana.com/docs/plugins/grafana-dynatrace-datasource/v0.9.4/ - it was causing me a prod troubles :cold_sweat: because it was unexpected. I have had also support ticket for this issue.
