Tip Error 404 page not found
Hi, I’m trying to configure kvrocks dashboard on grafana and the kanban dashboard all says 404 error
grafana version: 7.4.5
Kvrocks Grafana dashboard template:Kvrocks | Grafana Labs
I tried to access /proxy/api/datasources/proxy/1/api/v1/query_exemplars and it returned 404, but when I access /proxy/api/datasources/proxy/1/api/v1/query, I get the data
Where should I change this request path?
Hi @df673011332,
Welcome to the :grafana: community support forums !!
Unfortunately, I do not know what and where these settings need to be fixed as this seems like a community-based Dashboard and such errors appear mostly due to version mismatch or configuration issues.
The best will be to contact the provider on their Github page and ask about it (I did not find the link to their GH page as otherwise will post here directly).
Also, as a tip, check the logs as it might be able to help you out.
I hope this helps.
